IETF LAKE
This working group is intended to be a narrowly focused activity intended to produce at most one LAKE for OSCORE usage and close.
The working group will collaborate and coordinate with other IETF WGs such as ACE, CORE, 6TISCH, LPWAN, and LWIG to understand and validate the requirements and solution. draft-selander-ace-cose-ecdhe is a candidate starting point for the LAKE produced by the WG. Any work available from TLS or other WGs that satisfies the determined requirements will also be evaluated for suitability, but does not preclude the WG from freely selecting its preferred LAKE for OSCORE.
Details at https://datatracker.ietf.org/wg/lake/.
